Technical suspension noise
Kennif Fiat
Hello all,
My stilo active sport bangs when going over a hole or very uneven surface.
I'm sure it's not shocker, and last time I looked the springs were good.
I'm told by a mechanic it may be the rubber the spring sits on. (presumably there is a rubber above the spring too.)
It has been making the noise since I had the car 5 years ago, I always thought it was a deformed bush, causing metal to metal under load.
The left side the mechanic says is the culprit. He says about £40 parts per side.
Any one had the same trouble and what was the fix.
Many thanks
Could have sworn I put rear....what a silly old duffer I am today.
left rear...sorry.
