Styling 3 Door front bumper onto 5 door
andyblackett
Darlington, United Kingdom.
Ello
Does anyone know if the three door front bumper (the abarth one with gaping big holes just crying out for mesh) can be fitted onto the five door version.
Just been comparing, both cars look quite similar at the front end.
Any help appreciated
Andy
02 Stilo Dynamic 5 door. Orion Grey. Soon to have 17" OZ Volcanos
I don't know but if car manufacturers are true to form and there will be a tiny but massively significant difference!!
Roja
2003 Silver 3-Door Abarth with graphite wheels and all the toys
Sounds about right! Probably similar after market bumpers available though...
Roja
In width 5D and 3D has about 2,8 cm difference but i dont know if its only the plastics.Even if its not only the plastic you can extend the bases of the bumper with hot air so it wont crack.
5D 80 Fiat Stilo Dynamic Metal. Loden Green
athanasie i hope you dont mean to heat up the plastic enough to soften up and move it cause i dunno if that sounds very secure if the mounts had to be melted back into another place.
1.6 silver dynamic 3d with skywindow and silver rims.
You only heat up the angle of the plastic its a soft plastic its not so hard as you think and its the only secure way unless you cut the bases and you put new
I knew I'd seen it done somewhere before! Now try to find out how is going to be the hard bit
Andy
02 Stilo Dynamic 5 door. Orion Grey. 17" Fox 2's in Titanium
Definitely looks the dogs danglies - would definitely swap mine over if it's not too much hassle...
________________________________________________
I have a drink problem...only one mouth but two hands!
1.6 Active 5 door in Crystal Green.
UPDATE
I've managed to get a hold of the name and email address of the owner of this car. Have just emailed him.
His mate said its definately off a 3 door. I'll let you know if and when I get a reply
Andy
I've had an answer :D
<blockquote id="quote"> face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">Hi Andrew,
it´s no problem to get the 3d bumper on a 5d Stilo. You need only a small knife, to resize some (inner) parts on the bumper. Only under the light is a small edge, which does not fit exactly. You need a new bumper, an also new protection strip (i hope you unterstand this) an 3 new cooling grids.<hr height="1" noshade id="quote"></blockquote id="quote"></font id="quote">
Might have to wait till after christmas but I'm seriously thinking of doing it!
Andy
