General stilo cd changer
sly
United Kingdom.
anyone know a place walsall or brum area that would fit supply/fit the cd changer to my fiat stilo?
anyone done their own?was it easy?where was the best price for the kit?
any info would be great!
ta.
The only place you can get the unit from (if you are talking about the 5 disc glovebox unit) is from Fiat as far as I am aware. Other units are not compatible - Even the one that looks the same direct from Blaupunkt. Don't know anyone that would fit it up your way though.
Roja
2003 Silver 3-Door Abarth with grahite wheels and all the toys
you can buy the cd changer from here
http://www.cel-direct.com/oecd.asp?car_manuf=Fiat
or here
http://www.add-a-cdchanger.co.uk/acatalog/SHOP_Home_Page_Fiat_Stilo_470.html
mossy
the add a cd changer one looks right will have to see if fitting grief though!
thanks for info.
ta.
Is there an MP3 changer for stilo?
Andreas (CY)
Fiat Stilo 1.6 3Door Dynamic, Metallic Black, 16" Alloys, Dual Zone Climate Control, Steering Wheel Radio Buttons.
If you've got Connect Nav, fitting the changer is easy - did it within a half-hour one lunchtime at work!
The hardest bit was finding a mate with some security screw bits so that I could remove the upper glove box tray and fit the new glove box tray with the DIN insert that came with the changer. (And that wasn't that hard!!!!)
Wouldnt a Visteon autochanger work? I had a look at the back of the stock unit from mines and it has some sort of Din connector (similer in style to the iso one) and that it also has the CD control support.
Found this one here
http://www.caraudiodiscount.com/acatalog/visteon_cd_changers.html
Scorg
Stilo Dynamic 1.6
Sky Blue
