Hi. I bought the original set (2 headlights, 2 adjuster and abarth cable harness). I build in everything. I have to plug 3 cable from the right lamp (f10 connector 9-11-12pins) to Body Comp (M1A 10pin, M1B 28 and 35pins).
My big problem is, I have a 16v Multijet 150CV and my BodyComp is different. The original abarth plug has 2*20pins. I didn't have any 40pin plug on my body so I need a wireling diagram, nut eLearn also shows the 40pin connector..
mine <- ->normal
mine <- ->normal
