Old 23-07-2005   #1
Howard Jones
crashbang's Avatar
crashbang has donated!
Strange antifreeze problem
Hi again (Fiat Stilo Dynamic 1.6 52 plate) I have had this for 12 months, it has been serviced twice still only done 22.000 mls.
I have always done checks on usual things.
but lately (last 2 weeks) anti freeze is disappearing at an alarming rate.
I top up with water, next day after 5 mile run, down to minimum again.
No apparent leaks or drips, no water in oil, water temp O.K
Also after all this time, whilst checking under the bonnet, I didn't even realise that it was electric powered steering (no wonder I could'nt find the top up DOH! )
crashbang is offline Reply With Quote Quote
Old 23-07-2005   #2
Whaddya mean too old?
Deckchair5's Avatar
Deckchair5 has donated!
Re: Strange antifreeze problem
I presume you mean you're losing engine coolant when say antifreeze disappearing.
First question is have you experienced on engine overheat recently, ran out of engine coolant?
The water's got to be going somewhere so worse case is head gasket gone, water turned to steam and disappears down exhaust.
Symptoms might be poor starting, brown froth at oil filler cap or in coolant top up tank, cold heater, gurgling noises in water pipes
Could be water pump leak in which case the leak, if it's small enough, running onto hot engine makes water evaporate.
Symptoms usually see drips of water on floor and pump will start to make grinding noises and get progressively worse as pump bearings wear out
Could have heater leak inside car
Symptoms antifreeze or dampness smell in car
Could have radiator leak
Look for traces of a large leak, blue deposits on track of leak
It needs sorting pronto and don't run the car if the engine is overheating at any time as it'll be guaranteed expensive cylinder head gasket replacement
02 Stilo 1.6 Dynamic 3 door
99 Bravo 1.2SX
Deckchair5 is offline Reply With Quote Quote
Old 23-07-2005   #3
Howard Jones
crashbang's Avatar
O.K I'll get it sent in soon, going to Spain Monday, YEEEEEHAAAAA!
Old 23-07-2005   #4
Deckchair5's Avatar
Not in your Stilo I hope
99 Bravo 1.2SX
(T) Strange Clutch problem Julio_Scorchio Cinquecento / Seicento 21 16-11-2008 02:02
(T) Strange problem Orinocco Bravo / Brava 3 02-03-2005 20:09
(T) Strange noise and start up problem. El Greeno Uno 18 23-02-2005 09:47
(T) strange abs problem nitrous_HGT Punto (Mk2/2b) 19 18-11-2004 13:11
(T) Strange indicator light problem happened today!! peterp Bravo / Brava 4 15-06-2004 02:39
