im Axle Specialists
Old 07-08-2014   #1
Netherlands
I Give up with this problem any ideas i need help
hello everyone i have talk before about this problem . coolant temp sensor failure
so i have put a video about this problem . the check from obd2 says is coolant temp and intake air temp sensor . so with service garage we have change the 2 sensors <intake air temp and coolant temp > the problem still on . check the wiring everything is normal with 5volts we have check if there is any cut . there is nothing . the ecu working perfect . the plugs from the ecu to the sensors getting 5volts everything good . so whay i still get this error because the car not working when this error is on .obd2 still showing the same errors even with clearing the faults is coming back immediately . so any help any ideas I really appreciate it .
this is the video
otaqi is offline Reply With Quote Quote
Old 11-08-2014   #2
Maigretnz has donated!
New Zealand
Re: I Give up with this problem any ideas i need help
Can you monitor the actual temperature being given with MES? A spike up or down may indicate an intermittent fault with a plug, wire or dry joint on ECU
Maigretnz is offline Reply With Quote Quote
Old 11-08-2014   #3
Yellow Peril has donated!
Did the garage clear the fault codes? If not, I believe it takes several 'good' starts before the messages disappear...
Phil
Yellow Peril
Then:Yellow Stilo 1.6 16V 3-door - not quite standard
Now: Red Stilo Abarth Schumacher GP Prodrive - modded for function over form...
Yellow Peril is offline Reply With Quote Quote
Old 13-08-2014   #4
Netherlands
thanks for feedback guys . we have check the ecu is work normally there is no problem with ecu . i have take the ecu to the company they repairing ecus and softwears things. so yeah everything is okey the wiring getting 5 volts there is no cut. and even with clearing faults this error is not gone . still on . even is not disappeared and then comin back . no is not going at all just when click on clear botton is the error on dash is flashing and still on . so really i dont know what to do . i'm thinking to change the thermostat this the last solution.
Old 13-08-2014   #5
GPz750 has donated!
Could the coolant temp sensor failure be a red herring? I was getting all sorts of warnings when my battery went low. If it was on a good charge I got the abs warning all the time. I bought a new battery and all problems have gone. Nice quiet car on start up with no warnings.
Likes pgainf liked this post
GPz750 is offline Reply With Quote Quote
(S) please give me some ideas, thanks dan2467 Grande Punto 4 22-11-2013 14:53
(G) I give up :@ ideas anyone... corky Punto (Mk2/2b) 14 11-02-2011 14:48
(T) any ideas what this problem could be? craig20102010 Bravo 16 15-09-2009 20:25
(T) Any ideas on the problem...? PandaPower2009 Panda 8 30-06-2009 10:07
(T) problem, any ideas? J005h Punto (Mk2/2b) 13 21-10-2008 23:49
