Old 06-08-2014   #1
Radiator Fan - Fuse/Relay Confusion
Hello,
The entire three years I have had my 1.6 5dr Stilo Active the engine would overheat when idling. I have always assumed this was due to the fan not working.
Fed up, I did some research (largely indebted to this forum) and I looked under the bonnet to find a 50 amp fuse in the F06 (low speed fan), no fuse in F07 (high speed fan), no relay in T06 (low speed fan) and no relay in T07 (high speed fan).
I replaced the 50 amp fuse in F06 with a new 30 amp fuse, as this is the recommended rating. This was all I could do at the time as I didn't have the other parts... But hey presto, no more overheating! To say I'm confused is an understatement.
Is there any possibility that the relay diagram on the battery cover is wrong? How could I have fixed the problem? Should I still buy the missing relays?
Many thanks in advance.
Ash.
AshPNE is offline Reply With Quote Quote
Old 07-08-2014   #2
mhowse has donated!
Re: Radiator Fan - Fuse/Relay Confusion
You may have a model that does not run the fan speeds via relay's in the fuse board but by means of an ecu controller, this was revealed not so long ago when another member of the forum had a similar issue, if you do a search you may find the thread which also has an image of the ecu fan controller located by the fan.
So you may have just had the blown fuse, so long as your fuse does not blow now and your fan operates as it should then would presume you too also have the ecu controller for your fan speeds and all is well , and must have a generic battery cover which with the risk of water damage to the fuse board would not advise driving without it fitted.
mhowse is offline Reply With Quote Quote
(T) Fiat Punto Active MK2. Radiator fan fuse location & air filter soloution? chicknchock Punto (Mk2/2b) 26 08-09-2012 12:49
(T) Radiator fan keeps blowing the fuse Oll1e Punto (Mk2/2b) 2 20-04-2010 13:04
(T) radiator fan relay bsafirebird Cinquecento / Seicento 3 05-04-2010 01:25
(T) fuse for radiator fan? Bushboy Cinquecento / Seicento 12 21-06-2005 10:41
