mohammedkhalam
- Nov 26, 2010
- 17
- 4
I have been having a problem like a squelching sound when reaching 1200RPM and its worsened now to even lower at idle.
I have been diagnosed with a faulty bearing on my AC pump which is not possible to replace. Been told to replace the pump but that is too expensive and not really worth it. I have been reading the forum and saw something so now instead of replacing the AC pump I was going to try a shorter belt bypassing the AC.
Problem is I cannot find the right measurement and was wondering if anyone knows?
Also what is the actual length of the original belt?
I did get a belt from a motorfactor which was too short but I returned it without measuring and sort of fell out with the guy in there! Long story. :/
Also does anyone know if the crankshaft pulley is ribbed or not. I have a 1.9JTD but the crankshaft pulley is not ribbed. It does have the lines running round it but they are not grooved, in fact they are pretty flat and I have been told this is an incorrect pulley.
Thanks in advance
Thanks in advance
