numero-uno
hello chaps.
my JTD 1.9 stilo 3 door is leaking coolant from the rear of the engine - big time..
I put the motor on axle stands this evening and could not pin point the leak.
It appears to be coming from above oil sump and dripping down.
Now the issue is, how on earth can you get behind the engine of a stilo?
There is no space from the top of the engine bay (fuel lines in way), and from underneath there is too much stuff in the way to even see where the leak is coming from.
Any suggestions to confirm where the leak could be originating from, and how on earth can you access the rear of the engine without dropping out engine?
Cheers.
Cheers.
