My stilo (52 reg 1.6) started stalling and the engine light came on. I got a p105 code (MAP sensor faulty) when I did a diagnostic. I even replaced the MAP sensor, I also changed my exhaust, spark plugs and coils. and yet I still have a bad idle. I suspect that there might be a vacuum leak but I'm not an expert.
I've also noticed my fuel is running out quickly ever since I replaced my bad exhaust. I've erased the code and reset my ECU and still the car still has bad idling and the engine light keeps coming up (P105 MAP sensor faulty).
I took some data from the diagnostic in case is helps......Thank you in advance !!
