STILO BLKD
- Jul 9, 2005
- 2
- 1
My 02 stilo diesel air con compressor is not turning we have traced back to the relay in the fuse box not pulling in (fuse is 0k), if you manually work the relay the compressor works. Air con light is on on the dash. Has anyone any info?. If the refrigerant is low on pressure is there a pressure switch to stop the compressor running? also the main fan doesn't run when the air con light is on. Anyone got a wiring diagram?
