Our 2004 Active AC has decided to chuck a wee problem my way. Door mirror on the passenger side broke, changed this and had to remove the door card.
Put it all back together and all seems fine. Sister then said you can open the door from the outside, but not the inside. I think to myself perhaps I didn't reconnect the internal cable within the door which connects the lock to the handle.
However the door will unlock when pulling the handle (after drive lock as kicked in), just not open. So is this more likely to be a failed lock mechanism
