Technical Stilo Abarth Not Starting
RichyRich101
Hi All
Hopefully one of you can help!
I have just bought a Stilo Abarth that doesn't start.
Turns over fine no problem, but no spark, have checked the earths and main engine to body ok with no drop in volts.
getting fuel. display says "loose connection" and is throwing a faults in, esp, abs etc
have measured resistance of crank sensor and get .856, Ma when turning over is 1.2-1.37 so preety good? not sure what the resistance value should be though?
Any help appreciated, like i say got fuel just no spark!
its a 2004 model :)
cheers
Rich
further to post above sorry, i check the ma and resistance on the brown plug at top of engine at back - i believe this is the crank sensor?
not sure what the black plug goes to but this reads a resisitance of 4.86
plugging in my reader and all i get is 5 codes, one for each cylinder saying Po205 Injector Circuit/O5en Cylinder 5 (po204 fo rcylinder 4 and so on)
No, don't think so mate, too many warnings on dash and says loose connection too on dash display.
Its electrical but not immobiliser :)
Getting Somewhere! Stilo Abarth now running!! no electric windows though
As title.
Got the old girl running today (corroded fuse in fuse box after all the checks), no electric windows though, can hear clicking both sides when switch pressed, any ideas, car has stood since circa June last year so could be just stuck - sunroof is the same, sight click heard but zero movement.
