Technical fiat stilo 1.8 16v 2004
razar123
peterborough
hi guys i was wondering if you could help me out i have just bought a fiat stilo 1.8 16v 04 plate and it has that airbag failure message and i dont have a laptop so i cant use that version of Diagnostic so i have been looking at handheld and came across a U480 Obd-ii OBDII OBD2 EOBD Diagnostic Code Scanner CAN-]Bus Trouble Code Read Diagnose Tester Diagnostic Scanner could you tell me if it would work with my car thanks
If you have the airbag light on try first with cheap fix, check under seat connectors clean them or remove them completely and solder them, clean connectors in the boot, you can find them hiding behind the side holders and one inside the lower glove box at the tope you will need to open a plasti bit and the connector will fall out, just disconnect and clean it with contact cleaner. All of the connectors can be cleand with it and dont forget to disconnect your battery. Hope this helps
