Right rear wheel 4cm lower than the left one.
ZachAlexandru
And exept that today i noticed that my right rear wheel its lower than the left with 4 cm.. i dont know how the suspension works on stilo but if you have a idea please tell me cuz i posted to another thread that i hear a sqeec noise when i`m passing over holes and bumps...
Do you mean the wheel is closer to the ground on one side? or the body is closer to the wheel?
Only way one wheel can be lower that the other one is if the tyre pressure is lower, or you have the wrong size tyre on one lower wheel.
i mean from the body to the wheel,its weird around 3-4 cm difrence between the back wheels and not a single noise...
Broken spring (replace both)
Weak spring (replace both)
Collapsed mountings.
Different sized wheels?
i`ve been to the mechanic and discovered that the braking piston was stuck on that part and kept braking all the time....after they unlocked it its simetrical on both sides no broken springs....thanks everyone for the advices:D
