JTD Monkey
Member
I think it is valid the 1.4 makes the 1.6 redundant. I drove a 1.6 and found it totally underwhelming. The 1.4, with it's 6-speed close ratio gearbox would be just as perky (if not more so) on the road with this being a relatively new engine (the 1.6 powered the Ark in a previous life).
The only performance statistic these two differ heavily on is the 0-60 run which is down to the 1.6 being able to hit 60 in 2nd (therefore requiring only 1 gearchange) where as the 1.4 does it in 3rd (therefore needing 2 gearchanges) because the gears are shorter. This will make the 1.4 more responsive on the road.
And the 1.4 is much more economical.
The 1.4 16v 6-speed Active Sport 3dr with A/C (always an odd omission on the spec sheet) looks like a mighty fine but as it is only £10K (plus discount) at the moment
