Well, finaly found out the reason of difficul cold starting....
Faulty injectors...
The fix should cost about 600€....
I'll try to find used ones, and if they work, the Stilo is up for sale... I can't take it anymore....
Have a look at www.mister-auto.co.uk for the injector.
Taking used injectors out can be a pain.
Do as follows: use a lot of carburetor(!) spray around the injectors to free the carbon and gunk, let it soak for some time (days).
Loosen the clamp and try to pull the injector out, still using a lot of carburetor spray.
If the injector stays stuck, leave the nut on the clamp loose, but don't take it of completely, start the engine for a few seconds, compression will push the injector free in most times.
Thank you for the advice. I've checked the site above and they list two different Bosch injectors against my engine code and year but the price varies a lot so I think I need the info from Fiat regarding the modification notice C5603/ D5603 ... Can anyone help please?
Modification codes C5603 and D5603 refer to new injectors that were fitted from 15th November 2001 at engine number 2805542. If your car was built up to that date and has up to that engine number you will have the injectors shown with C5603. If built after that date and has after that engine number you will have the injectors shown with D5603.
If you hover over the modification number (C5603 or D5603) in ePER, it will show the modification.
Both are the same reman. injectors, and are OK for your car.
The less expensive injector is based on exchange of your old injector(s), the pricier one isn't.
Those are remanufactured injectors by Bosch, as real new ones are VERY expensive...
Thank you all it says hovering over the modification number is that it was substituted in later vehicles but does not say what the change was or if I should fit the later number. It says ... DAT 10-2001 MOT 2805542 if this measns anything to you?
