im Axle Specialists
Old 06-06-2013   #1
ABS and traction failure
Grateful for any information or thoughts on this one: JTD 1.9, starts OK but when braking under 30mph the brakes feel as though the the ABS is kicking in like when you break hard at speed (judders). Once you go above 30mph the brakes work fine, even under hard braking without locking up, but the ABS and traction failure lights come on with associated warnings. Discs and pads are all good, and there is no pulling when braking.
The Bishop is offline Reply With Quote Quote
Old 06-06-2013   #2
Moderator
Davren's Avatar
Trader Rating: 5
Davren has donated!
Re: ABS and traction failure
Check all 4 wheel speed sensors and their connectors. Easiest way would be a diagnostic scan for codes. That will tell you which sensor or connection, if any, is faulty.
Stilo Parts For Sale: Connect Nav+ Map Discs - Wiper Motor (NEW) - JTD/JTDM Front Brake Discs (NEW) - 5 of 215/45-17 Alloy Wheels
For details, click here: http://www.fiatforum.com/classifieds...0&ppuser=48514
Davren is offline Reply With Quote Quote
Old 09-06-2013   #3
Thanks Davren. Waiting for the code reader interface to arrive on Tuesday.
(T) ABS Failure neonglow Stilo 11 14-06-2011 19:50
(T) ABS and Traction control warning lights keep comin on?? dal31 Stilo 8 24-12-2009 12:49
(G) ABS failure EBD Failure Switch off engine Call Garage Handbrake lamp on SillyBilly Multipla 0 15-03-2008 21:16
(G) Traction Control failure dannyjohnston Stilo 7 14-02-2008 19:58
(T) ABS failure krca Bravo / Brava 5 02-11-2004 23:15
