hi guys looking at big brakes for the summer, full 330mm.
now ive searched for big brake conversions and seem to be fiat coupe(305mm)calipers or full race stuff (new)
so looking at creating a fairly cheaper version, so far I have some discs sorted
lancia delta 111 (2008 - 2013) 1.8 turbo
ebc EBC Brakes Standard Vented Discs D1765
Vented Disc; 4 Bolt Holes; 330mm Diameter; 45mm Height; 28mm Thick; 26mm Minimum Thickness
found the brembos discs now also
09.A500.11 approx.£115-£130
http://bremboaftermarket.com/En/Car_...1-6973e7fa3a03
now does anyone have any info on the bolt holes for the brake calipers?
if it makes a difference to mounting lugs, my car has 281mmx 26mm sd brakes
hole size ?
threads, pitch?
hole centers on calipers/hubs?
hole distance from center of hub to design adaptor plates ?
had a look in eper and no details of stuff above
early days yet may all depend on finding cheap good calipers .
basically plan is to fit delta discs, most probably lug mounted 4pot calipers mounted to an adaptor plate to convert hole centers and also space to suit the 330mm discs.
I have std 17" blade alloys(although I will need a full size spare as spacesaver /steelie) probably wont fit over larger calipers.
I also already run with 15mm hubcentric spacers so have quite a bit of clearance from caliper to back face of alloy.
any info welcome otherwise I will need to strip and measure up one weekend.
edit on a side thought I could just go with the delta discs and space out further my oe calipers? not sure on clearance inside caliper for a disc 2mm thicker.
should order the discs really then no going back.
hole size ?
threads, pitch?
