Old 15-03-2013   #1
Portugal
Angry Coolant pipe has broken
I have a broken pipe near the termostat sensor. It's the one that comes from the coolant vase (the thin one) and I don't know what the original hose looks like.
Does it screw in the engine or must I buy a complete new piece where the sensor is screwed?
Please look at the picture and give me some help.
Thx.
Bravo 1.4 16V T-Jet 150 hp; ex UNO and Punto owner
ovarb is offline Reply With Quote Quote
Old 15-03-2013   #2
Moderator
Davren's Avatar
Trader Rating: 5
Davren has donated!
Re: Coolant pipe has broken
Which engine do you have?
Stilo Parts For Sale: Connect Nav+ Map Discs - Wiper Motor (NEW) - JTD/JTDM Front Brake Discs (NEW)
For details, click here: http://www.fiatforum.com/classifieds...0&ppuser=48514
Davren is offline Reply With Quote Quote
Old 15-03-2013   #3
Portugal
Quote Originally Posted by Davren View Post
I've got a 1.6 - 16V engine.
Old 15-03-2013   #4
Moderator
Davren's Avatar
Trader Rating: 5
Davren has donated!
The pipe is only supplied as part of the thermostat.
Name:	1600 Thermostat.JPG
Old 15-03-2013   #5
Portugal
Thx for the exploded drawing but it doesn't look like mine.
Besides, in what's left from the broken pipe there is a 12mm (look at the picture)
Old 16-03-2013   #6
Moderator
Davren's Avatar
Trader Rating: 5
Davren has donated!
It's the diagram from ePER (the Fiat parts catalogue) for the 1.6 engine. It's not an exact diagram, but if the metal pipe was available seperately, it would be shown.
Old 18-03-2013   #7
Netherlands
Hi Ovarb,
there are some options, all depending on your budget and willingness to experiment:
new thermostat will be about 100 euro
second hand thermostat via eBay around 45 euro
or you check out what thread size the old connector has and you start googling for something lik "hose connector 9mm" and pick something that looks similar, like https://www.landefeld.de/gruppe/en/t...101640/GT53MSV. I found almost only thread in inches. In this case you might be able to spend only a few euro's (but beware that with the wrong thread you might permanently damage your thermostat or with the wrong material you might get galvanic corrosion). Maybe your local garag might help you out with this.
Chiuaua is offline Reply With Quote Quote
Old 18-03-2013   #8
Portugal
Re: Heater radiator
Thx you all.
I solved the problem by buying a second hand.
I refited it all but I noticed that the heater matrix is clogged.
Is there a guide about removing the heater matrix in order to clean it or replace it by a new one because the interior doesn't heat enough and Portuguese weather is cold?
PS: It isn't a problem of faulty termostat or circuit bleeding.
(T) HGT Coolant Pipe NottsCharger Bravo / Brava 1 18-05-2010 11:24
(G) Coolant distribution pipe Crashtest33 Panda (Classic) 10 27-09-2008 14:05
(T) Coolant Pipe problems fatty Cinquecento / Seicento 3 27-04-2008 11:47
(G) Broken Pipe asaywell Stilo 10 04-02-2007 19:31
(T) coolant pipe bigpigeon2004 Cinquecento / Seicento 7 11-12-2005 16:49
