Technical Dipped beam headlights issue..
bbrm
Coventry
basically ive a dipped headlight issue, as soon as i turn the key in the car to Mar or ignition my dipped beam headlights light up and stay on. I've written down what happens per each action of the stalk.
no key in ignition, nothing.... [FONT=&quot]emergency [/FONT]lights work
Ignition set to MAR- dipped beam lights on, no dashboard lights, (light stalk switch off)
Engine on - dipped beam lights on, no dashboard lights, (light stalk switch off)
Engine on, lights set to sidelights: sidelights on, dipped beam lights on, dashboard lights on (sidelight symbol on dash too)
Engine on, dipped beam set: everything on as should be.
Engine on, full beam set: everything normal
I have tried swopping the relays over with a like for like one, I've also checked every fuse relating to the dipped and main beam all the fuses are ok
Does anyone have any other suggestions? I like the idea of Daylight running lights but dipped beam all the time? sheesh! lol :)
Lee
Ahhh should have reworded that to Engine on instead then :)
the headlight level symbol isnt there until i turn the stalks onto dipped headlights then it shows up.
And I assume removing the relays in turn turned off each side in turn? Also does the follow me home headlights mode function still as well?
Sounds like its potentially a body computer fault.
Right, just tried the follow me home lights, and the parking lights. The P button plus left or right indicator works so I can choose ether sidelight to be on.
However, when trying to get follow me home lights to work the whole dash cluster lights up for a split second and goes off but no external lights come on. Also leaving the lights on after the engine is switched off brings up ars and abs text warnings which go away as soon as the lights are switched off.
body computer fault sounds expensive... :( bad earth maybe? :\
