Yeah you can do it, there seems to be 3 different ways depending on your Stilo. Some have the wiring already there in the column shroud so in the case you just plug in the cruise control. Others have less wiring which ends under the engine bay fusebox, in this case you need to hardwire the cruise control plug pins to the pins on the "spare" wiring plug under the engine bay fusebox. The last one is where you have no wiring, in this case you need to hardwire the cruise control stalk plug pins straight onto the 4 spare pin outs on the engine node.
