Hello everyone,
today I have replaced my headlight washer pump, windscreen washer pump and disconnected and reconnected everything in front driverside doors. After I wanted to try everything out, after I turn ignition key, every light in the car starts blinking, and also you can hear samo relay ticking fast (related to blinking probably) from engine. What could I have done wrong?
Car wont start, after I try to start it, it just drains power and restarts blinking (which stops after like 10 seconds, then I get all possible error/fault messages, including loose connection).
Before that everything worked perfectly with no problems whatsoever,
One more thing, i dont know if that is relavant or not. Before those errors, when i was testing pumps, i got EBD failure error... which i thought will go away after few starts, so I didn't bother with it, since everything was working.
Thanks..
Thanks..
