evening all, and congrates on what looks to be a useful site.
I am new to the stilo world and have been trying to idetify a noise underneath the car on the drivers side. by the way it is a 115hp estate.
I removed the first part of the shaft with no problems (other than every bolt appearing to be siezed solid), some play in the shaft, which I think I will get reconned, unless anyone knows of a good supply if them. But this is where my problems started. The cup for the first part of the shaft (gearbox end) would not come off. On most cars I have delbt with they just pop off. I guess I need to remove this to get further into the bearing houseing for the intermediate shaft.
Is it just tight on or do I need to remove the 3 17mm nuts to allow it to come off? I did have a quick go at trying to undo these but almost impossible to get a spanner on, and no change of a socket. So if I do what do people usually use?.
I also tryied to get the housing off, i could get the nuts on the mount off on the bottom, but then again there is a 15mm nut just above the intermediate shaft which i could get a socket on but no room to turn.
Is it normall for this bearing to go?
i hope the explaination is clear enough if not please ask. any advice would be gratefully recieved.
