Thread Tools
Old 16-08-2012   #1
STONKING has donated!
Where are the injectors 1.6L 16V
Hi, I think I need to change the injectors so I brought a CD on how to do it but I cannot find them. 51 plate. I have taken the big cover off the engine. Back right appears to be a 2inch rubber hose that I guess is the air inlet. ECU is middle to front right. 4 off spark plugs in the front and the injectors with fuel pipe is ......
STONKING is offline Reply With Quote Quote
Old 16-08-2012   #2
Stiloooooooooooo
JayEm's Avatar
JayEm has donated!
Re: Where are the injectors 1.6L 16V
First of all, how do you know you need to replace the injectors?
JayEm is offline Reply With Quote Quote
Old 17-08-2012   #3
That escalated quickly...
Trader Rating: 1
james2609 has donated!
China
Very rare for injectors to fail, do you have any error codes on ECU scan? Is it running rough or using a lot of fuel?
Previously owned:
1988 Panda 4x4 S/R Grey (Flynn) 1987 Panda 750l Red (Grace), 1988 Panda 1000CL Red (Fran), 1986 Panda 1000CL Red (Poppi), 1992 Panda CLX White (Meg), 2004 Panda Dynamic Black (Bella)
james2609 is offline Reply With Quote Quote
Old 17-08-2012   #4
Well it is on other posts I have had on this forum. Basically a garage said 3 injectors are not working properly and it could also be the ecu. Well I have had the ECU checked out and that is perfect so its back to the injectors. I have done the check of the resistance from the plug thing and they all give the same reading of 16 so I am down to sell the car with a judder at 2000 rpm or try and check out the injectors so first thing has to be, where are they. I guess I could follow the wires from tha plug thing that I tested.
Regards
Old 17-08-2012   #5
Trader Rating: 7
Shadeyman has donated!
If your sure its an injector problem remove all 4 injectors and send them to this guy.
http://injectortune.co.uk
He's good, cheap and fast ...
Shadeyman is offline Reply With Quote Quote
Old 18-08-2012   #6
CFREITAS has donated!
Smile Re: Where are the injectors 1.6L 16V
injectors are common fail, on the 1.6 16v engine, they are located under the steel inlet manifold
theres alot of work to remove them
Good luck
Fiat Bravo HGT 20v
Fiat Bravo HGTT 20vt
Fiat Bravo Trofeo
Fiat Marea HLX 20v
CFREITAS is offline Reply With Quote Quote
Thread Tools
(T) what injectors are used on the 1.6 16v? arc Bravo / Brava 5 15-05-2011 15:33
(T) fuel injectors 1.6 16v murphy2010 Stilo 3 13-02-2011 18:52
(T) injectors on the 1.6 16v? arc Marea 3 24-08-2009 17:55
(T) 1.6 16v injectors PAN366E Multipla 5 14-04-2008 09:52
(T) Brava 1.8 16V injectors TBel Bravo / Brava 0 04-01-2004 05:56
