Technical Where are the injectors 1.6L 16V
Hi, I think I need to change the injectors so I brought a CD on how to do it but I cannot find them. 51 plate. I have taken the big cover off the engine. Back right appears to be a 2inch rubber hose that I guess is the air inlet. ECU is middle to front right. 4 off spark plugs in the front and the injectors with fuel pipe is ......
First of all, how do you know you need to replace the injectors?
Well it is on other posts I have had on this forum. Basically a garage said 3 injectors are not working properly and it could also be the ecu. Well I have had the ECU checked out and that is perfect so its back to the injectors. I have done the check of the resistance from the plug thing and they all give the same reading of 16 so I am down to sell the car with a judder at 2000 rpm or try and check out the injectors so first thing has to be, where are they. I guess I could follow the wires from tha plug thing that I tested.
Regards
