![]() | #1 | ||
Posts: 35 Thanks: 0 Trader Rating: 0 ![]() | 1.9 MJET starting problem Hello Everybody ! So, I have a 2006 Fiat Sitlo with 1.9MJET 120HP engine. Sometimes when i try to start the engine, i can not to start first. But if i dont move the key to MAR position after the engine is starting but looks like the ignition is interrupted ! If the engine hot is ok if the engine cold is ok but if the temperatur is around 15-25 C i have a interesting problem. I have made a video and i share it . I like to find any souliton. The car was in the fiat service. no error, nothing. The last OS is loaded in the ECU and the CR system is working perfetclly. ( the car was in a BOSCH serrvice too ) So, now i have not more solution. I tried to clean the MAF sensor ( i can ) but nothing. here is the link thank you
![]() | #2 |
Posts: 726 Thanks: 35 Trader Rating: 0 ![]() | Re: 1.9 MJET starting problem Have you checked your glow plugs / Battery cranking amps ?
__________________ 2019 Rosso Exotica Abarth 595 ![]() 2017 Rosso Amore 500X Mjet 4x4 ![]() 1999 Rosso Corsa Coupe 20VT ![]() |
![]() | #3 | ||
Posts: 35 Thanks: 0 Trader Rating: 0 ![]() | Re: 1.9 MJET starting problem Hi, I checked everything. I replaced the battery and nothing. the glow plugs looks like ok because i cheked step by step one by one. Ok! i did not remove the plugs only i cheked with AMPER meter and looks like OK
![]() | #4 | ||
Posts: 8 Thanks: 0 Trader Rating: 0 ![]() | Re: 1.9 MJET starting problem Hi! I have exactly the same problem on my 05 Stilo 1.4 - did you solve it?
![]() | thevoid | Idea | 3 | 22-08-2011 18:50 |
![]() | carattano | Grande Punto | 0 | 24-05-2010 07:34 |
![]() | peter7889 | Grande Punto | 10 | 02-05-2010 19:16 |
![]() | alexh365 | Grande Punto | 17 | 17-07-2009 21:54 |
![]() | billett | Bravo | 7 | 22-06-2009 16:40 |
