whity
Hello Everybody !
So, I have a 2006 Fiat Sitlo with 1.9MJET 120HP engine.
Sometimes when i try to start the engine, i can not to start first.
But if i dont move the key to MAR position after the engine is starting but looks like the ignition is interrupted !
If the engine hot is ok if the engine cold is ok but if the temperatur is around 15-25 C i have a interesting problem.
I have made a video and i share it .
I like to find any souliton. The car was in the fiat service. no error, nothing. The last OS is loaded in the ECU and the CR system is working perfetclly. ( the car was in a BOSCH serrvice too )
So, now i have not more solution.
I tried to clean the MAF sensor ( i can ) but nothing.
here is the link
thank you
here is the link
thank you
