I did an overhaul on Abarth and troubles don't come to an end.
I now have problems with rough idle. Which i understand can be just about everthing. Do you guys have any suggestions what to look on parameters for potential cause?
I also changed clutch (renew it actually) and it's also rough on clutch release. Rod is 12.125mm which should be 15.700mm I believe. I tried to do throttle learn, Clutch degradation index by FES instructions and it nothing happened. Clutch degrad. index is still 10683 for me same as before clutch rebuild.
I read in elearn that if you repalce ecu or throttle body you should do learn process on the first start of the car with new components. After that you can disconnect battery without losing data. So by my flawless logic you actualy can't reset or partialy reset ecu or throttle body with disconecting battery since everybody suggests that with different figures from 30 min to over-night.
Overhaul by amateur.
