Thanks for your reply guys.
So I picked up the car yesterday and it worked just fine, they had also fitted new rear brakes and passed its MOT, I drove to the pub to sob over the money spent and rejoice that my car worked again.
When I left the pub, key in the ignition and nothing happens. I tried a couple of times but nothing. Checked the radio, noted the time still showing on the dash and the car lights on and central locking works. Key back in the ignition, hold it the the car comes to life engine fires, warning comes up saying excessive radioot fluid temperature and the car cuts out violently. Tried again, same warning wont start. Key out, talk dirty to my car key in and it worked. I drove home, turned off the engine, waitied 5 mins, started again all ok.
This morning I start the car, all good, pull away and bang, it violently cuts out, and the ignition is totally dead. Electrics all good. BUT when i turn the key nothing happens on the dashboard at all, turning the key has no effect on the car whatsoever.
I have noticed they filled the coolant up quite a bit over the max level, Poss culprit?
i going to trawl some posts now but currentlyu I am the proud owner of a Stilo Door stop and £450 worse off
