Old 22-06-2012   #1
Rallying Crazy guy
nikkiy9 has donated!
Gearbox/Clutch woe
hey there guys, driving along and i start to get a whine, dip the clutch and it's gone, carry on driving and the car desides to jump out of 3rd, if i hold it in place it jumps out but suddenly it's back in 3rd,
drive the car to the in-laws (3 miles away) and the whine is really bad in 5th, yet if i dip the clutch it's gone again,
does this sound like a clutch issue or box issue??
i'm gonna do a gearbox oil change tomorrow
nikkiy9 is offline Reply With Quote Quote
Old 22-06-2012   #2
StiloBoy has donated!
Re: Gearbox/Clutch woe
From previous experience with minis this happens when the idler gears get worn, meaning popping out of hear when you hard on throttle and lift off suddenly.
If its the clutch your looking at about 350 for replacement, if its the gearbox too then its gonna be expensive.
Ex- 53 plate, Stilo 3-door, Sassy grey, newly refurbished 17" Claw Alloys, Avon ZV5 tires, 1.2 Active
http://www.fiatforum.com/gallery/data/500/26348.png
StiloBoy is offline Reply With Quote Quote
Old 22-06-2012   #3
Rallying Crazy guy
hmmmmm, the clutch was changed in feb, the noise only started today, gonna see if i can just make it last a while longer by changing the oil and checking metal shards to come out
Old 22-06-2012   #4
Slovenia
Gearbox is a unit which needs quite some effort to brake it. It has to be clutch.
If you have a hole in gearbox try to look through it if something is moving and it shouldn't. I have a selespeed which has hole your should have it too.
Now I read your post again. If your third and fifth gear are worst and I look at diagram of C.514.5 gearbox 1st and 2nd are on layshaft but 3,4 and 5th are on main shaft if last three gears are causing whine you should focus on gearbox.
Assuming that you have 514.5 box.
I just renewed my clutch driven plate for 25.
Which car you have?
oowop is offline Reply With Quote Quote
Old 22-06-2012   #5
With no oil gearboxes don't last very long... I know I wrecked a Ford box this way completely unaware that the oil had all pished out.
Back to minis the killers of the idle gears is folk who hold a car in gear when driving. I.e. driving with hand resting on stick for miles on end. I don't know if this applies to all gear boxes but the design of a manual has got to be fairly generic.
Old 22-06-2012   #6
Rallying Crazy guy
I've got a jtd 115, the other half took the car to her parents and didn't have any whine from the box, still gonna change the oil tomorrow
Old 23-06-2012   #7
Rallying Crazy guy
UPDATE,
Couldn't remove the old oil due to a seized drain bolt, so topped it up (I know I shouldn't of but still......)
Took the car for a run which I knew would cause the box to whine, not a whimper out of it, so that's me a happy teddy and one quiet gearbox
Old 23-06-2012   #8
No such thing as a seized drain bung eat weetabix and try again... If you still show yourself up as a weed then have more weetabix and use your Allen key but put a ring spanner onto it for more leverage... Carefull not to slip cos it REALLY hurts If you do
Likes Peat, saw liked this post
richydraper is offline Reply With Quote Quote
Old 23-06-2012   #9
Rallying Crazy guy
It was seized dude, had the torx attached to a foot long power bar!!
Old 24-06-2012   #10
Springer Mad!!
Muppet1's Avatar
Muppet1 has donated!
That sounds tight, Is it worth spraying WD40 at it.
Don't know if it will work or not.
Muppet1 is offline Reply With Quote Quote
Old 24-06-2012   #11
Slovenia
I just hate seized stuff. I had a crankshaft bolt seized which took a 2m long extension and even then I barely undo it.
It's nice to hear that was just oil issue. What i find strange oil in gearbox is meant to last lifetime of gearbox without touching anything. So why it was missing? Maybe somebody fiddled with gearbox and also screwed that drain plug to much (just in case) which would explain seizing.
My plug was never touched and I unscrewed it with my weak hand easily.
Old 24-06-2012   #12
Rallying Crazy guy
GAME OVER!!!!!!!!!!!!!!!!!!!!!!!!!!!
drove back from newcastle, went to come off the motorway and i couldnt get gears easily
got the car parked up onto ramps and i could see the oil fumes venting out, so climbed under and here is the final nail in the coffin
Old 24-06-2012   #13
Rallying Crazy guy
Update, an ex fiat tech has offered to change the box for 110, and found one for sale also for 80
Likes Shadeyman liked this post
Old 28-06-2012   #14
on the pluss side, you got that old gearbox fluid out :P. haha. chin up fella something will come along soon XD
Likes Peat liked this post
clock34 is offline Reply With Quote Quote
(G) Clutch & gearbox change - Mr.Clutch - Mk1 Punto 60S FiatMAW Punto (Mk1) 13 08-01-2011 21:03
(T) clutch/gearbox help taffy20779 Punto (Mk2/2b) 2 24-09-2009 16:41
(T) gearbox or clutch? dan-the-man Stilo 9 08-06-2006 22:35
(T) Changing hydraulic clutch gearbox to take a cable clutch? 4paws Uno 10 23-03-2006 14:56
