if fuses check ok and wiring power to washer pump located at bottom of washer bottle when button pressed with ignition on not need motor running needs someone in car to press button or extend test leads is also ok or as I did just remove pump and test on 12v battery...if these ok then you would check tubing for blockage and washer pump for signs of blockage just pulls out of bottom of washer bottle ..you will loose contents of washer bottle when pump removed when mine went I used plain water while testing for repair save wasting washer fluid. would imagine though if front and rear not giving fluid is electrical or pump faulty or blocked
In the end mine was the washer pump and replaced for about a tenner from a hunt on ebay for new one..remember if you do replace pump to connect tubes in correct order else you will still have problems easy enough to swap tubes around if you have to replace pump to find correct order tubes fit..needs think I just removed top waher bottle fixing nut and managed to get my hand down to pull washer pump..not an expensive fix if pump
