Guys im having a problem my temp fluctuates past the mid mar to max and then back to mid. it does it whenever it wants or when i have high revs. i changed the water temp sensor but that wasnt it.
i noticed if i lighlty tap the ecu it stops. I cleaned the connectors and wiggles them around to see if there is a cable problem but no fix.
I have a feeling this is an ecu problem. Has anyone had this problem before? A new ecu is pretty expensive here. I heard you cant get a used one cause its locked with the immobilizer. Is there any way this ecu can be fixed? any reputable companies that do this?
