Old 03-06-2012   #1
Trader Rating: 7
Shadeyman has donated!
Pierburg MAP Sensor and Boost Gauge .
Spent this morning helping a friend install a boost gauge to his JTD. He's tuned it and likes messing so I went round to give him a hand.
This was the boost gauge we installed, works quite well.
http://www.ebay.co.uk/itm/330729815146
I've attached Pierburg MAP Sensor PDF that he gave me to the post. It contains info some of you may find useful.
Shadeyman is offline Reply With Quote Quote
Old 03-06-2012   #2
Re: Pierburg MAP Sensor and Boost Gauge .
Hi I'm wanting to do the same in my 150 jtdm bravo ( fit a boost gauge ) and was wondering ware you connected the pipe from the back of the gauge to ? I believe I need to measure intake manifold pressure ?
griff83 is offline Reply With Quote Quote
Old 04-06-2012   #3
Trader Rating: 7
Quote Originally Posted by griff83 View Post
Contact Greg(https://www.fiatforum.com/members/chappers14) I fitted his for him.
He'll be able to supply you with photo's of where and how I drilled and fitted a quarter inch thread, one eight barbed hose connector(pictured below) to the plastic elbow on the inlet manifold.
@chappers14
Old 04-06-2012   #4
sussexa has donated!
not sure on bravo layout?
does this help
http://img855.imageshack.us/img855/7...fly2011004.jpg
p.s. the aquarium valve really stops all the needle buzz. nearly shut still gives good readings.
sussexa is offline Reply With Quote Quote
Old 17-08-2012   #5
Trader Rating: 1
rat20v has donated!
Quote Originally Posted by sussexa View Post
does this help
is this your stilo sussexa? is this the best place to fit it /easiest?
cheers
robin
rat20v is offline Reply With Quote Quote
Old 17-08-2012   #6
Trader Rating: 7
Thats where I installed Greg's(Chappers14).
I though it was the best place.
Its easy to drill and seals very well. Plus the part(and the hole in it) can easily be replaced if the gauge is removed.
I installed it closer to the manifold and pointing rearward so the pipe lay a little more flat under the engine cover.
Thanks rat20v thanked for this post
Likes rat20v liked this post
Old 18-08-2012   #7
Trader Rating: 1
rat20v has donated!
Quote Originally Posted by Shadeyman View Post
that looks really good that buddy, thats where i will mount mine as that pipe is only plastic too, so will be easy to drill, plus what connector did you use buddy, i take it that it bolts from the other side to, so that it create a nice seal with teh rubber washers?
Old 19-08-2012   #8
Trader Rating: 7
Quote Originally Posted by rat20v View Post
No rubber washer or nut needed.
I used the same connector as pictured above but with a tapered thread so it self sealed as I tightened it into the plastic. No need to remove the pipe this way, just be careful not to let any of the plastic swarf drop into the hole.
What cars use the same MAP Sensor, Coolant Sensor and TDC Sensors as 1997 1.1 Punto ? d1ckyboy Lets Talk FIAT 6 26-10-2011 23:45
(G) map sensor and boost sensor CNapperturbocrazy Grande Punto 7 09-01-2011 21:57
(T) HT leads, MAP sensor, Lamda sensor & dizzy cap ashar786 Uno 1 30-06-2008 01:37
(T) punto 1.3 multijet MAP sensor & IAT sensor spence Punto (Mk2/2b) 0 14-06-2008 09:25
(T) Oil on MAP Sensor & Sensor wires scorched?! DaveX Stilo 6 09-09-2006 08:17
