steviestilo
- Feb 22, 2012
- 8
- 1
I have had an intermittent issue with ABS cutting in for a while on my 1.2 Stilo, at first only at low speed. Lately it started cutting in on every journey and usually I get the ABS warning beep mid-trip and then no more problems since the ABS is disabled until car is restarted.
(I have had to disconnect one of the sensors at the moment to make it safer to drive as ABS was extending stopping distances.)
I bought a cable and ran FiatECUScan which says the front right sensor is to blame so I replaced the sensor which didnt solve the problem - its just the same.
Ive also cleaned all the electrical connectors under the bonnet and the C12 earth etc
From reading on here it looks like it could be:
Dirty/Damaged Sensor (now cleaned and replaced)
ABS Reluctor Ring Damaged - is it possible to get to this to visually check it or clean it up? - If so how I tried sticking a paintbrush in the sensor hole and rotating but is there a way to get access to clean/check?
ECU Problem (hope not)
ABS Pump Problem (hope not)
Replacement Bearing with ring needed - (if too damaged?)
I have a multimeter so if someone could explain how to test the sensor/ring - i understand that you can kind of count the teeth on the ring on the mm somehow.
Or any other suggestions of what to try would be much appreciated as MOT is coming soon... Thanks
