novatron1_2
I bought my OH's stilo about two years ago with a duff head gasket and the water pump knackered (all the plastic blades had broken off)
Today she mentioned it was overheating, I took it for a drive and it engine warmed up fine then started to overheat. When I stopped and opened the bonnet the fan was running fine when the ignition was switched on, the top radiator hose was burning hot but the bottom one was cold, I can only think the water pump has failed again? (It's only been on for ~30,000 miles, it was from Eurocarparts and had metal blades)
Any other ideas? I don't think it could be the thermostat as the the top hose is after it.
