Technical 1.6 engine fault/bouncing idling/no throttle when starting from hot.
nnnick
Hi Guys,
New to the forum, but have used a lot of the guides before so a big thank you for those!
I've searched through a whole load of other similar problems, but I haven't found one that seems to be near whats going wrong with my Stilo!
About a week ago my car stalled, came up with an engine fault but seemed to drive OK, so I made it home, checked the guides online and cleaned out the throttle body valve. This seemed to work great, the car revved to about 2,5/3k rpm on ignition, no warnign light, and drove great...
For about 10 miles :(
I had stopped the car for about 10 minutes, got back in and started the engine from hot, drove a couple of miles and had an engine fault warning light come up, pressing the accelerator had no effect, and the idling rpm bounced between 700 and 1.3k rpm. nn
When i restarted the engine the fault maintained, and the car continued to idle awkwardly, but I could use the accelerator for about 30 seconds before cutting out again.
When the RAC came out, they reset the warning, and the car seemed OK to drive home. I don't have the exact codes, but I was told the fault was the Manifold Absolute Pressure or Mass Volume Airflow circuit out of range.
Took it to the garage and they could not replicate the fault, so I took it away to see how it went. Sure enough, 5 days later this fault has come up again, under the same circumstances of starting the car from hot. Had the car towed back to the garage, and got them to give the car a full service and MOT as this was due and a service was much needed!
After it passed an MOT and had been serviced, left the garage with the engine still warm, and the same fault happened. Took the car back and they've been trying to fix the problem today. They've thoroughly cleaned the whole throttle body unit, and have checked the engines timing.
It seems a really strange fault as the car will drive fine from cold when the fault has been cleared!
Sorry for the long post, but if anyone has any suggestions or have had some similar experiences I'd really appreciate any ideas!
Will post if the garage manage to sort the problem!
(Fiat Stilo Dynamic 3dr 1.6 2003 75k miles)
VERY typical of failing crank sensor... clean it thoroughly and check the air gap (should be between 0.5mm and 1.0mm). Expect to replace it if the air gap is correct and it still happens.
if its a 1.6 petrol it probably, from your description, would have thrown a MAP sensor fault of
P0106 Manifold Absolute Pressure/Barometric Pressure Circuit Range/Performance Problem
other MAP sensor faults are
P0105 Manifold Absolute Pressure/Barometric Pressure Circuit Malfunction
P0107*Manifold Absolute Pressure/Barometric Pressure Circuit Low Input
P0108*Manifold Absolute Pressure/Barometric Pressure Circuit High Input
P0109*Manifold Absolute Pressure/Barometric Pressure Circuit Intermittent
try searching for "P0105" or "P0106" it might give you some more clues and just try the resetting procedures (in my sig) just to eliminate them ;)
when changing your crankshaft sensor does not solve your problem you probably need a new ecu - i can supply a revirginised plug& play ecu for a decent price, please pm when you are interested...
Replacing the ECU sounds a little excessive for an intermittent fault? Its in the garage over the weekend, I'll ask about the crank sensor and see what they say.
If they do suggest replacing the ECU, I'll let you know yellowstilo, cheers for that!
