FIAT Auto Specialist Team
Old 23-02-2012   #1
fender mender has donated!
throttle housing
can any body tell me if i remove the complete throttle housing from my 1.6 2002 stilo do i need a gasket to put it back & do i hav to do a relern or any thing like that or will the car just start again when its put back on
fender mender is offline Reply With Quote Quote
Old 23-02-2012   #2
Netherlands
Re: throttle housing
There's a rubber ring inside to seal it on the manifold.
Search on throttle relearn and the procedure is easily found.
gr J
"Look for the ridiculous in everything and you will find it". - Jules Renard
A3jeroen is offline Reply With Quote Quote
Old 24-02-2012   #3
thanks for your help funny no body on the forrum here knows
Old 24-02-2012   #4
Croatia
Last year I removed complete throttle body of my 1.6 (2002.y), cleaned it with some kind of MAF cleaner. There is no gasket to replace.
You have to unscrew 4 bolts that are holding it to the manifold, also unplug the connector.
I think that cleaning this way is better as you would be able to clean it from the "inner" side. Don't push butterly spring too hard... After that, just screw it back and do the throttle relearn. It is simple.
Here are some pics:
http://imageshack.us/photo/my-images/197/maf04.jpg
http://imageshack.us/photo/my-images/508/maf05.jpg
http://imageshack.us/photo/my-images/8/maf06.jpg
http://imageshack.us/photo/my-images/528/maf09.jpg
and how it looks clean...
http://imageshack.us/photo/my-images/841/maf10.jpg
http://imageshack.us/photo/my-images/24/maf11.jpg
ivand is offline Reply With Quote Quote
Old 24-02-2012   #5
Netherlands
Quote Originally Posted by fender mender View Post
What do you mean: Nobody knows...
You got an answer in two hours didn't you?
Old 24-02-2012   #6
thanks very much for the photos and when i said nobody knows i ment now body exsept you 2 have helped with any of these probs i seem to be having with this 1.6 stilo so thank you for all your help im hopeing this will do the trick if not then i have to mabe see if it is the cam belt that is causing me these big problems
Old 24-02-2012   #7
Croatia
Maybe it is not sufficient to mention that in my case I have an extra wire connected to throttle body (from negative battery terminal). I beleive this "grounding" was done previously in service, maybe due to some kind of problems.
Old 24-02-2012   #8
thanks Ivand ive got my job tomorrow if the weather is ok ive cleaned it from the air filter side so now i will take it off and clean it proply and spray some contact cleaner on the plug will let you know how iget on
Old 25-02-2012   #9
well took it all of to day after changing the front pads on the wifes stilo cleaned it all out both sides of the butterflyi made it so clean you can eat your dinner of it waited 3 hours before reconecting the bat did a full throttle relern but still does the same thing take your foot off the pedal and the revs drop right down almost cuts out and then picks up to where it should tic over i also noticed yesterday when i was reversing on full lock it kept trying to cut out can somebody put me out of my missery (HELP)
(T) Going to take off and clean throttle housing david295 Punto (Mk2/2b) 1 01-07-2011 21:14
(T) Thermostat Housing MikSun Uno 6 02-09-2010 20:09
(T) 105 JTD - Where is Throttle Body / Throttle Potential Sensor b1gduk Marea 4 22-01-2006 20:53
