hi guys, i'm toying with the idea of fitting (or rather creating) a tuned up performance head on my 2.4. obviously such a head is'nt avalible "off the shelf" so i'll have to do it myself. the head i had in mind would be gasflowed on both ports, matched to the manifolds, use fast road cams and possibly bigger injectors with a gasflowed thottle body.
now anyone who has gasflowed a head before will know that it can take a while to achive the finish you desire (some expert books sugest up to 1 hour on a single port!!) so, because i use my car regually, i thought about sourcing a cylinder head and working on it when i can buying the parts i need as i go along and fitting it all ready in one go.
so heres my questions..... there are'nt many 2.4 cylinder heads about but i have seen plenty of coupe 20v ones so the first thing i need to know is can i use a 2.0 turbo/non turbo head on my stillo block? is there a difference between the turbo and non turbo versions, also are there any performance gains from using a turbo aluimum manifold over my plastic variable one? and if i fit bigger injectors and a performance cam, will it mess with the fueling and run lumpy?
