Old 17-02-2012   #1
That escalated quickly...
Trader Rating: 1
james2609 has donated!
China
Stilo in limp mode, what should I look out for?
Hi all,
My Stilo has been timed up and is now running, but in limp mode.
Itís running poorly and the errors coming up are loose wiring alternator and all 4 injectors (according to the mechanic).
Itís been recommended by FF members to take the battery off and charge overnight as poor charge battery can give a multitude of ghost codes, put a little WD40 under the block and reset the ECU. Iíve told my mechanic to do this, and also check the crank sensor to make sure itís working and not bent in any way.
Is there anything else I should be looking out for?
Previously owned:
1988 Panda 4x4 S/R Grey (Flynn) 1987 Panda 750l Red (Grace), 1988 Panda 1000CL Red (Fran), 1986 Panda 1000CL Red (Poppi), 1992 Panda CLX White (Meg), 2004 Panda Dynamic Black (Bella)
james2609 is offline Reply With Quote Quote
Old 17-02-2012   #2
Just getting another beer
Stealth123's Avatar
Stealth123 has donated!
Austria
Re: Stilo in limp mode, what should I look out for?
Having extreme cold weather and a dud battery might make those problems arise. Have your battery tested first and it would be good if you give the details of your current battery. For the Stilo, the bigger the better, I could only go for a expensive Austrian Banner battery Uni Bull 50 300 rated at 69Ah, as my car is under a warranty I cannot put a bigger one in but even better is recommended.
My previous battery was tested good but Ah was only 58 so it needed more in this weather and my Stilo was giving endless problems and eventually refused to start.
Take it one step at a time, but surely your mechanic should not be asking you what needs to be done!
Stealth123 is offline Reply With Quote Quote
(G) 04 Stilo keeps going into limp home mode P0220 olly0404 Stilo 29 20-05-2016 23:00
(G) Stilo in Limp Mode pachamama Stilo 10 29-11-2011 15:43
(T) Limp mode again wegi Bravo 8 08-08-2011 08:14
(G) limp home mode sporting chap Punto (Mk2/2b) 2 15-02-2010 09:40
(T) Limp home mode gtturbs Punto (Mk2/2b) 1 11-11-2008 19:11
