Technical How to measure oil pressure in 1.6 engine
Komárom
Hi.
Is somebody know how to measure actual oil pressure in Stilo 1.6. For sure the engine does automaticaly somehow and give and analog or digital signal to ECU. Or there is only a "switch" what is switch on if there is enough oil pressure after engine start?
Thanks in advance.
BR. Hurrican
Oil pressure sensor.
attachment.php
Here it is on a 1.6. This is front of engine
It's usually not far from the oil filter
And after market Oil Pressure Sensor can be installed here by teeing into where the OEM sensor fits.
