schumraid Patron member Parked in the garage Joined Oct 1, 2010 Messages 431 Points 92 Location Belfast Jan 30, 2012 #1 Evening folks, Does anyone know the torque setting for the two bolts that join the front struts to the hub? Thanks in advance!
Davren Moderator Staff member Uploaded 10+ resources/downloads Joined Jul 6, 2008 Messages 16,366 Points 3,858 Location London, UK. Jan 30, 2012 #2 eLEARN says 7 daNm but it also says for 10mm bolts. I think they ar 12mm bolts aren't they? It's not a torque critical application, so anywhere between "tight enough that it can't move" and "not so tight that the bolt snaps" should do. OR: Tighten it until the bolt snaps, then back it off a quarter of a turn.
OP OP schumraid Patron member Parked in the garage Joined Oct 1, 2010 Messages 431 Points 92 Location Belfast Feb 8, 2012 #3 Thanks Davren, wasn't too sure if they had to be done to a specific torque setting or not (nothing to do with wanting to play with a new torque wrench, honest ) Oh and the bolts are 10mm
N nikkiy9 Rallying Crazy guy Joined Jan 11, 2009 Messages 806 Points 244 Location Newcastle Feb 8, 2012 #4 I tightened mine until I couldn't get any move movement on the nut, (bolt held by spanner and nut on a wind gun)
