Technical Electric Seats Intermittent and P0170 Fault
jjjj
Hi all Can some one help I have a Stilo 1.8 dynamic year 2002
The electric front seats some times work and some times dont at present they have stopped working any ideas.
I have also had been told by the garage that there is a fault P0170 over fueling on bank one injectors but are unable to tell me the cause.
The symptoms are engine warning light , slow tick over / uneven revs seems to be missing and increased fuel consumption.
Intermittent operation of the seats is likely to be a poor connection to one of the electric motors under the seats, or the connector to the control switches/ECUs.
P0170 = Fuel Trim Malfunction (Bank 1)
Could be caused by air leaks in the pipework between the Mass AirFlow sensor and the inlet manifold, or a faulty MAF.
Thanks Davren Will check this out before going to Fiats
