Hi, could someone please tell me if one of the sensors out of the four is faulty, then this could stop the complete system from working ? also a BMW replacement could be used ?The car is an 03 stilo abarth. Thanks.
Yes. If one sensor is faulty the system does not work and sad to say you will need to replace it with a FIAT sensor - assuming it's an OEM fitting. Having said that, if the BMW sensor has the same plug/socket you can always give it a try.
