- May 5, 2006
- 894
- 214
Yellow Stilo, are your speedo's using KPH or MPH?
Sorry for the delay, i have both KMH and MPH clusters.
Garage said battery fine, no drain on it and fully charged and is powerful enough to start car easily. Car started once warmed up in the day!
Breakdown guy and garage I took to after who did diag with examiner and tested battery said cannot see why it didn't start...mystery.
In the old days one could start a flooded engine by pressing the accellerator all the way during starting and releasing it after the engine caught.
Although this worked fine on the old carburettorengines it won't work on our "drive by wire" Stilo's.
The only way of getting rid of the petrol is removing the fuse for the petrolpump and/or injectionsystem. IIRC that's fuse 17 (behind the battery) on a 1.6.
gr J
I had a go at getting the cluster out, managed it all but couldn't get it past the steering wheel once disconected, does it come past the wheel easily as I tried all ways!
I started mine a couple of weeks ago with accelerator fully down and it worked, does it mean I've still got petrol stuck somewhere then?
Just takes a few attempts to start now, think I will get a another battery very soon as now I have dead dash and trouble starting, didn't used to have either!
Thanks for all the help so far...good thing is I am still drivingh it with a sat nav for speedo!
Got a reply from ebay seller that JTD clusters only work in diesel stilos..is that correct.
Also anyone know what happens if I buy a petrol 1.4 or 1.6 one will that just plug in and work?
Thanks again all
yellowstilo I am looking for a cluster that is cheaper the car is 8 years old with 82k on clock, so I want to spend as little as possible there are a few on ebay for between £40 and £80 delivered and some I could collect so would get for nearer £40.
andreist31 so the abarth one will plug and work, but presume no mileage etc as its a different display to the LCD on 1.4 and 1.6?
Thanks again all.
Hi
This forum has really helped my problem with my instrument cluster, so here was my soloution. My instruments started to go crazy and die for periods of a few seconds to hours and then it completly died a week before my mot! Fortunately my brother-in-law has car tuning and diagnostic garage he plug his comp into my car which told us the obvious - the dash did not work - that did however eliminate other problems though like power supply etc... A call to my local fiat garage informed me that a replacement would be nearly £500!!! (fitted about £350 for the part) I could not afford this so I located a number of replacements on salvage websites ranging from £52 incl postage to about £80. I removed mine, fiddly but you can do it in under 15mins and fitted the 2nd hand one which worked straight away. ( There is only one plug/connector in the back of the instrument cluster) The car passed the mot with the new instrument cluster. One thing you will have to do if you want to resell you car is get the instrument 'proxy alligned' so the instrument cluster will display the correct milage for your car as a 2nd hand dash will display its original cars milage. I hope this helps.
Carl
andreist31 thanks for all of the advice, so upon plugging a new one in the speedo won't even work, fuel gauge etc? But it will only take 5 mins for a Fiat examiner owner to sort?
Mid Wales is a bit far from me in Bedfordshire, thanks very much for the offer though.
