Hello one and all.
yesterday I decided to fit a performance airfilter to my 115bhp Stilo mainly because I was fitting a new MAF and the clips on the Air Box had rusted to nothing.
I took the front cover off the air box and my filter was well caked up with flys and so was the mesh on the old MAF so perfect time for a change. My old MAF seemed to be caked in oil.
I took the rubber hose off the turbo , fitted a new section of pipe then a new Bosch MAF then a K&N filterwhich pokes into the old air box just under the cold feed.
The breather hose from the rocker cover was spliced and connected to the tank on the bottom of the air box.
Then the problems started, on start up my car was suddenly putting out loads of white smoke with a smell of burning oil????
Enough smoke to mean it cant be driven on the road.
I ran out of daylight by this time so went out again today and the smoke is less but big plooms when you rev the engine.
i took everything off that I put on yesterday and no change. Whilst there I put my fingers in the turbo and its spinning freely and there is no end float movement in the shaft. Put everything back together and checked I hadnt knocked something whilst in the engine bay but all seems in order.
Smoke has a slight blue tinge.
On tickover the car is perfect and drives fine but when the turbo winds up you can here what sounds like a loud scraping noise. Also when the engine is turned off there is sometimes a hissing,sizzling noise from the turbo area like the sound of water poured on hot metal.
Im baffled especially as the turbo seemed to be running freely , also until I changed the airfilter the car had never had such a problem.
May be coincidence its happened when I changed the filter or maybe the increased airflow has shown something up.
ANY IDEAS ??
ANY IDEAS ??
