Hello
I've got a yellow triangle with an ! mark flickering away again! I had it before but after having a new wiring harness fitted for a preheat fault it went. Then a week later it came back but this time it was a blown bulb, after a new bulb, it went again. However its come back and all the lights seem to be working, although the only thing i haven't checked is the reverse lights.
Could there be an electrical problem somewere? A bad earth? Fuel cut off switch? but saying that I've not pressed it, is it worth pressing it and see if that does anything?
Any advice or suggestions would be welcome. The car is a JTD by the way.
Just to add, there are no fault messages or codes with the warning triangle.
Phil
Phil
