Well got the car up and running today and its nice to say that i did it.
But a word of warning to anybody who needs to do it,
Allow at least 8-10 hours if you are doing it from the floor, I had the car on axle stands but could have done with more hight but beggars cant be choosy,
First off you need to take off drivers side wheel and engine cover.
Then disconnect the battery,
If your alternator belt is still on the car remove belt.
Oh and your plastic under tray if you have one and also the drivers side piece that the under tray bolts too, I didn't as i haven't got any.
Next thing to do is you will need to remove the drivers side drive shaft, Mine was quite easy as i had to remove the suspension strut due to having to replace the spring so i split the drive shaft where it go's into the cup, Basically just pulls out.
Next you will need to undo the rear bolt on the engine mounting bracket, This is the one that bolts around the driveshalf, Then there are 3 bolts on the C part of this bracket.
You may have too slacken the rearmost bolt where it goes in the floor of the sub frame to give you wiggle room.
Once you have removed this C section bracket you can the access the 3 allanhead bolts that hold the inner driveshalf into place. These are bloody horrid to get at and a 1/4 " little socket set is ideal though.
Once you have removed the 3 bolts from the drive shaft you can then with a lump of wood and a large hammer knock the driveshalf out of the gear box. I did resort to using a wide masonry chisel not ideal and you use on at your own risk but it soon moved the driveshalf.
Then remove the 2 wires from the alternator, 12MM and 8MM socket again this is where the 1/4 inch socket set comes in handy.
By the time you have done this, make yourself a cup of tea and a fag if you must
If its a Jtd then split the exhaust pipe just after the flexi bit, U will need to trust me!!!
Then from the top remove the tiny piece of pipe between header tank and engine, Next undo the earth wire under the ecu and unplug the two plugs that go into ecu.
Basically now wrap all that behind the engine so you can now see and get to the top bolt of the alternator, You can get to the nut from above thats hidden behind so get a spanner on it and the one that pokes out just above the chassis rail i ended up using a socket and two 1/2 inch extension bars to shift it.
Once you have removed the top one remove the bottom one again from under the car get the spanner on the nut and undo the bolt from the wheel arch end.
Once you have undone the bolt you wont get the bugger out until you drop the engine. Do that by placing a jack under the sump with a piece of wood, Take the weight of the engine and undo the 3 bolts until the end of the threads.
Drop engine slowly and remove bottom alternator bolt. That should then allow you to knock the alternator from the engine, Beware it will be tight then wiggle said alternator along the back of engine and down in between engine and bulkhead and push flexi bit to one side as well.
Careful because you will trap a finger whilst doing this. i do have the cuts to prove it.
Fitting is the exact reversal of the above, But you will know that as you have just done it.
I will take some pictures of must of the above point to show where and what i mean but didn't take any of the job in progress I'm afraid.
