Tuning Looking for a good Stilo JTD map file
Hi guys,
Does anyone have or know where I can download a decent map file for a Stilo JTD? I have the 115 version and have the interface to read and write a map files to the ECU, just looking for a decent one to try :)
Any help is much appreciated!
I've attached one to this post, give it a try.
Unzip and install.
MAKE TWO OR THREE BACK UP COPIES OF YOUR ORIGINAL BEFORE INSTALLING A NEW ONE.
Edit.
Changed my mind, have PM'd you, don't think its a good idea to leave it in the open forum. Its a Generic MAP, tried it in my own car, works really well.
  • Thanks
Reactions: Xen
I'm watching this post with interest as I have a JTD 115, would very much like to do the same, let us know how you get on!
I had a re-map done and the impact was immediate, so far as I could tell.
Unzip and install.
Edit.
hi Shadyman, can you please send the map to me too, very interested to try on my jtd stilo?
I think I've found the file on a back up drive.
I loaded it into the Galletto software with no problems but can't find my Galletto cable at the moment so am unable to try it in the car.
I've attached it to this message, just download and unzip it. You use this file at your own risk, no one but yourself is responsible if something goes wrong. Make sure you back up your original file before over writting it so you can revert back to the original if needed.
  • 2005 Fiat Stilo 1.9 JTD(Tuned).zip
i hope you dont mind but i have taken a copy of these remap files from Shadeyman. when i finally get my car back, i want to try a remap to see if i can improve things on my 115 JTD.
with remaps, do you get BHP increase etc?
Yes you will get an increase in BHP and Torque but most remap files are specific to the engine and ECU they were put into and wont work on another vehicle.
If you plan to try remapping your own car make sure you make multiple backups of the original map so you can put it back if things don't work out ..
ah yes I had just read up on this tonight, so thankyou!! Im going to have a look at doing it myself, although I have no experience. If i cant do it, ill send it off for remapping (y)
Hello, I have read all you talked about, and downloaded the files, I have alfa 156 1.9 jtd 8v 115 , will this work on my car, it ia same engine like in stilo. Ty
Hey mate did you ever install this tuned map? did it work? or did u need to get someone else to make u a remap?
