Hi there, I have a 05 Fiat Stilo Xbox 1.6 16v model.
Last year I remember topping up my engine coolant with Paraflu Up. I have recently read around that you are not meant to mix old Paraflu with new as it causes it to become a waxy substance that blocks up pipes.
Last winter my car was leaking a redish substance into the passanger footwell, believed to me to be engine coolant, leaking from the heating matrix. I bought some radweld as a temp fix really as it is meant to be able to seal pipes. It seemed to do the trick as I haven't since had any problems at all.
When I came to get my MOT last march, I was told there was next to no antifreeze in my engine coolant and so I got them to flush it out and replace with new. Therefore the leaking rad pipe may have been caused due to the pipes freezing up then expanding?? I'm not really sure??
Now it is coming around to winter and cold weather again I don't want the same problem to occur and there to be little antifreeze present in my engine coolant. My friend who knows a bit about cars said 'paraflu up' is the brand name for fiats antifreeze and that any antifreeze from halfords would be fine to top up with. However I have read about that you shouldn't mix different colours of antifreeze together as they contain different chemicals!
I am looking for advice on what antifreeze to top up with or if it doesn't matter really.
Thanks!
Thanks!
